hello
Yesterday I update from 3.5.2. to the last one.
I'm not enought pro to know if it is a bug or if I don't understand the change but i can't used any midi controler on the new version (try with bcf2000 and nanopad), it run fine on the oldest, it's like the new learn fonction don't work with the new. Of course drivers are ok and controler in run mode.
can someone help-me ?
Very good idéa to manage 2 controlers at the same time now !!!!
Problem with midi-usb
- FreeStyler Version: 3.5
- FreeStyler Version: 4.01
Re: Problem with midi-usb
Make sure in setup under midi settings that you have selected the correct devices then you should be able to map your devices. Many versions ago he started allowing two active midi controllers at the same time. When that changed so did the way they run. Once you get them setup the way you like you can export that file for future ease of setup.
Thanks for the answer,
I choose the right device in midi setup and try very lot of things .. now I 'll try on another laptop.
I have the same issue, after an installation of the last release my APC Mini don't work !!! It's work fine in 3.6.41
Confirmed, there is a midi issue on latest release, revert to 3.6.41 also submit a bug report
Ok so I will wait because I don't have the 3.6.41 and continue to use my old one few days ... exept if someone have a link ?
- FreeStyler Developer
- FreeStyler Version: 3.2.1
Send me an email and I will send you the latest beta fixing this issue. freestylersupport"at"telenet.be
Raphaël
