Hi everyone.
I have an issue with a pattern. I made some pattern in the pan/tilt window of my moving heads and put it on 10 for a very slow speed. Reason is I want to use it at the beginning of the evening. Everything looks ok, but when i save it, and run it as a cue it is not moving at all, just staying static. If i turn speed for that cue from 100 to 103, it suddenly starts moving but alot faster than it should.
I have checked the output window and indeed, at speed 100, no pan/tilt values are changed. It's driving me nuts
Anyone have any idea ? Or how do you create slow scanning cues for the start of an evening ?
Thanks upfront !
Slow pattern not working when played as a cue
- FreeStyler Version: 4.01
Re: Slow pattern not working when played as a cue
Can you post your fixture file?
Whops, don't know why, but i missed your reply partyman.
Here you go. Hope you can help me out.
https://we.tl/DibQ2mXY6n
thanks upfront !
thanks upfront !
- studijo
- FreeStyler Version: 3.5.9
Re: RE: Slow pattern not working when played as a cue
Petek, what happens if you run your created pattern in a sequence? Does the output window values for pan and tilt change?petek wrote:Hi everyone.
Thanks upfront !
Freestyler 3.5.9 on Windows 8.1 with DMX4All USB interface.
BCF2000 with firmware 1.10
Fixture setup: 4 x PAR64 controlled by Dimmpack, 2 x Eurolite TSL-200 scanners, 1 x Ayra TDC-33, 1 x Geni FL-1800D strobo, 1 x Antari Z-1500 fog machine
No they don't ... which is weird...
Thanks!
Thanks!
- studijo
Indeed, so if you use a default pattern like circle, it works but with your 'figure' it doesn't. Try to change the figure from your own to for example the circle...
How was your figure created? I always use an existing figure, modify it and save it as another name. This procedure works for me.
Verstuurd vanaf mijn SM-G920F met Tapatalk
Have you tried adjusting channel 5 on your fixture you may be trying to move slower than the fixture is capable of or is set for
