Error Message
Nick300
FreeStyler Version: 3.6
Error Message
Post by Nick300 »
I have a problem, when I open freestyler it gives me a error message. It says universe 0 interface: open failed. I'm trying to set a light bar Chauvet ColorBar SMD 3ch. But I don't have any control of the light at all. I'm using a Enttec opendmx usb.
FreeStyler Version: 4.1.6
Re: Error Message
Post by Rod_Horning »
Basic questions:
The opendmx is plugged into a USB slot on your computer?
Windows recognized the controller?
Freestyler is configured to use the Enttec Opendmx controller?
Any possibility of testing the controller on another machine to make sure it is working?
Nick300
Re: Error Message
Post by Nick300 »
I have tried on 2 different computer's with the same results. I also hooked 2 lights together with a daisy chain and a separate controller for each still comes up with that message.
FreeStyler Version: 4.01
Re: Error Message
Post by Partyman »
are you sure you have the drivers installed for Enttec?
Nick300
Re: Error Message
Post by Nick300 »
When I install the drivers it tells me the drivers on my computer are newer than the ones I'm trying to install so it doesn't install them.
Re: Error Message
Post by Partyman »
Nick300
Re: Error Message
Post by Nick300 »
I'll try them when I get to work but that looks like the same file that I already downloaded.
Nick300
Re: Error Message
Post by Nick300 »
I installed that file instead and I didn't get the message about the drivers being newer on my computer. I still have a problem when I open Freestyler it gives me this message Universe 1 interface: open failed.
Re: Error Message
I don't know if this will help but review the following web page(s)
https://www.enttec.com/?main_menu=Produ ... 3&show=faq
Click on OPEN DMX USB doesn't work with my PC ?
Re: Error Message
Post by Partyman »
Also, what windows version? It may be windows related
Nick300
Re: Error Message
Post by Nick300 »
Partyman wrote: March 6th, 2017, 12:58 am Also, what windows version? It may be windows related
I'm running Windows 7 Home Premium, Processor Pentium R4 Cpu 3.40 ghz, Ram 512 Mb, System Type 32 Bit.
