no server fsremote bluethoot help
josesilva
FreeStyler Version: 3.6.3
Post by josesilva »
Hello I bought the app fsremote via bluethoot and I can not download the server thank you help thanks
barrypearce
I Use FreeStyler for: Band
Re: no server fsremote bluethoot help
Post by barrypearce »
viewtopic.php?t=6002#p26302
Bluetooth is no longer a supported option according to the above thread...
josesilva
Post by josesilva »
Ok thanks I also have the wireless application but I can not connect without having internet I would like to know if it is possible to connect without internet ... thank you very much
barrypearce
I am using a tplink wireless router, Enttec ODE via ArtNet. Asus tablet running Freestyler with Android remote control using the full version of the freestyler app.
This runs as a system on its own without any internet access. The enttec is cabled to the router. the tablet with freestyler is connected to the wireless on the router and from there to the enttec. My android phone is set to connect to the router wifi (yes this will take internet access away from the device - but hey Im running a gig not checking email!) because the phone is connected via wifi I just need the IP address of the tablet and I can connect direct to freestyler . In windows go to a command prompt and type "ipconfig" that is the quickest way to find your IP address.
Is this the sort of setup you are looking to achieve?
josesilva
Post by josesilva »
Thanks barrypearce I'm going to test
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
Barry has the best advice for how to connect without an active internet connection,
very interested to know where you 'Bought' the bluetooth app from as this was pulled from sale last year??
josesilva
Post by josesilva »
Hello Mattotone thanks for the help I bought the bluetooth application in the play store but I already bought a router and I can control through the wireless application also bought in the play store I did as barrypearce advised me and gave some compliments to both ...
