Hey everyone, so i've hit an annoyance when setting up Freestyler Midi control....
I want make lots of cuelist buttons with various patterns, combinations ready to be triggered from the cuelist buttons via MIDI- the freestyler Midi Control setup only seems to allow me make midi links for 16 of them, but i'm going to have more than 1 page of cuelist buttons (as it allows you to make), is this really a limitation in the software, not being able to midi trigger any more than the first page?
I can midi trigger up to 32 override buttons, but theres not much use in those as it only plays the first frame of a sequence, a cuelist gives me loads of flexibility. I dont want to sit there pushing colors, gobos etc all night, i want to be able to premake cuelists for triggering so i can get on with other stuff like VJing at the same time.
Am i stuck now with more than 16 cuelist buttons but no way to trigger the rest of them?
thanks!
Midi Control - Cuelist Buttons
- FreeStyler Version: 3.4.1
- Spirit
- FreeStyler Version: 3.5.9
Re: Midi Control - Cuelist Buttons
you can switch between pages with midi.
and if you know how MIDIOX or bome midi translater works you can create functions to Switch to page and cue button with one midi button.
or you can look at TUI2 (touchscreen userinterface2) here you can add all 96 cuelist buttons to TUI2 page.
- FreeStyler Version: 3.6.3
- I Use FreeStyler for: Band
Is there a link where I can get more info on how to assign and flip between the different pages via MIDI? I've been messing around with it, but must be missing something obvious because I can't figure it out.Spirit wrote: ↑February 5th, 2015, 8:17 pm you can switch between pages with midi.
