Acme 56/64 LED Color Parcan 4ch
Download other Magic 3D Easy View Fixture files created by the community here.
Pmarten8
LJ
FreeStyler Version: 3.3.6
Twitter: http://twitter.com/looneychoons
Post by Pmarten8 »
This Is Magic 3D Easy View Fixture File That Should Be Used With
http://www.freestylersupport.com/fsforu ... =72&t=3251
Reason: Removed zip file attachment, please attach exported *.pff files only! They are zip archives and contain everything needed, including images.
FreeStyler Version: N/A
Re: Acme 56/64 LED Color Parcan 4ch
Post by remco_k »
Pmarten8, welcome to the FS forum and a big thank you for you effort on creating all the fixture files you have been posting.
But, there is a but.
We don't allow zip files to be attached here, neither do we allow *.fxt files.
We only allow exported *.pff files to be attached to the topics. (see fixture creator->File->Export).
Those files have several advantages, one of them is users can easily click them, and they are automaticly imported in FS. Another advantage is that *.pff files automaticly contain all the images needed (like gobo's, colors, the fixture itself, you name it). *.fxt files don't.
You could see *.pff files as a FreeStyler customized zip archive. It makes life easy.
So, I know you've been busy, but please re-attach your fixture files, export them from the fixture creator. That creates a *.pff file. You can attach that to your existing posts.
Da_Boom
FreeStyler Version: 3.5.5
I Use FreeStyler for: Church
Post by Da_Boom »
hey remco_K, this fixture was made for 3D-easy view.. not FS... so why have you removed it? it was in the correct forum right? so i am kind of confused this is in the Magic 3D Easy View Fixture Files forum.. so it should contain the fixture file for 3D easy view.
Or should he have just renamed the zip to a pff.. just to satisfy this?
Correct me if i am wrong.. i am new here!
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
Hey,
Just to let you know that if you are putting files for 3D easy view on here, it's not .pff or anything like that. It's the SSL2 extension that you need, but like remco_k said we do only accept .pff not zip in the topics for freestyler fixtures.
If you need any help PM a moderator :)
liarschair10
Just started using FS
I Use FreeStyler for: Band
Post by liarschair10 »
dang,I had no idea there were fixture file police here...not very friendly at all...
Return to “Magic 3D Easy View Fixture Files - User Created Downloads”
