No connection between FS and Easy View 3d
armino28
FreeStyler Version: 3.5.5
Post by armino28 »
Hi!
I've added some fixtures in FS and conrolled the devices. Worked fine.
But my problem is, that the fixtures in Easy View 3d doesn't get any signal.
Here's what I've done:
  • FS dmx controller: Virtual Interface
  • Opened Easy View 3d with the FS toolbar
  • used Art-Net (also tried SandNet)
  • added the same fixtures than in FS with the same addeses
  • Tried to change values in FS (not working)
Any Ideas what the problem could be?
Greets
Armin
Nathanrs93
FreeStyler Version: None
Re: No connection between FS and Easy View 3d
Post by Nathanrs93 »
Hi
What version of FS do you have? What is your OS?
spud1511
FreeStyler Version: 3.5.7
Post by spud1511 »
[url=viewtopic.php?f=56&t=5997&start=10]viewtopic.php?f=56&t=5997&start=10
Copy mevp.dll from c:\freestyler\mevp.zip and overwrite the one in c:\freestyler folder. Then chose freestyler when you launch from freestyler toolbar
armino28
Post by armino28 »
@Nathanrs93
FS Version: 3.5.5
Magic 3D Version: 14.321.0.414
OS: Win 8.1 x64
@spud1511
I replaces the dll file. Still not working. Btw do you mean with that: "Then chose freestyler when you launch from freestyler toolbar"?
spud1511
Post by spud1511 »
I mean with that, the 3d easyview button from freestyler menu you get a prompt box for where to get dmx from (artnet, etc). if you successfully replaced the old mevp.dll (so it is no longer the old one from 2007 in the file properties) then it will give another option for choosing the dmx from freestyler.
