Freestyler --> Magic3d
veedubnutz
FreeStyler Version: 3.5.4
Post by veedubnutz »
I see a lot of you are having issues with the latest version of Fs and Magic view which I also echo... However, if I perform the upgrade steps mentioned, the Magic view button in FS stops working, and if I launch MV on it's own the DMX shows as offline. Any ideas?
Nathanrs93
FreeStyler Version: None
Re: Freestyler --> Magic3d
Post by Nathanrs93 »
veedubnutz wrote:I see a lot of you are having issues with the latest version of Fs and Magic view which I also echo... However, if I perform the upgrade steps mentioned, the Magic view button in FS stops working, and if I launch MV on it's own the DMX shows as offline. Any ideas?
Hi there, veedubnutz :)
Have a look at this thread here. It might solve your problem..:)
Click here
If it still doesn't work after then post a reply and I'll be sure to help you out :)
veedubnutz
No dice I'm afraid. Even after a full reinstall and following your steps Magic3D won't launch from FS so I'm at a loss :(
veedubnutz
Thought I'd try this on my spare machine with a fresh install... New error! When launching M3d I get a "failed to open DLL functions error".... Ugh
Nathanrs93
veedubnutz wrote:Thought I'd try this on my spare machine with a fresh install... New error! When launching M3d I get a "failed to open DLL functions error".... Ugh
I got this error for a while, but I just copied the files over one by one, carefully and it fixed itself. If you want I can get my files and upload them for you, it might get you working magic 3D again?
