Dmx through [SOLVED]
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
Hey,
This might sound silly and stupid but what does it mean when a piece of equipment has DMX through on it? Does it just mean that it goes straight through and doesn't operate it or what?
It still has DMX in and Out, but just wondered what DMX through is and when you would use it?
Nathanrs93
Re: Dmx through
realy strange is it 5pin DMX?
but normaly dmx out is a Through as most fixtures have a Little "Y" construction inside them (yes i know a "Y" cable is wrong..... but most cheap fixture have it... even the cable inside the fixture isnt 120/110ohm. ;)
i only know a Midi thru and this will send the midi in directly to the TRHU port whithout changing the signal.
Kings
Commited FS Forum helper
Re: Dmx through
Post by Kings »
What is the make/model?
Nathanrs93
Re: Dmx through
It's on an ILDA type interface for lasers. Picture posted below
See...
Re: Dmx through
ahhh yes
Midi in , Goes to Midi through, same as normal fixtures.
the Midi output is a build-in DMX controller on the phoenix device and can be controlled from the Phoenix software..
so a DMX + ILDA all in one.
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Re: Dmx through
Post by buttza »
Yeah, I have 1 on a LSC DMX Splitter. I usually just use it as an extra DMX Out. :)
If I use 2 DMX splitters on the same universe then I will use the THRU to patch to the next DMX Splitter.
