enttec open dmx Sowtware bug
TurtleForGaming
FreeStyler Version: X2
Post by TurtleForGaming »
Hi, I recently make a enttec open dmx conttroler of a ftdi and a max485 (Img: http://imgur.com/gallery/wLaQ6) but after adding my 4 switch and 2 rgb par I'm having a big problem with the software.
As you see on the picture I have two led on the front witch symbolise for the red one the power and for the green one the tx of the ftdi.I don't know really why but somme time the soft stop sending data to the board and when I try to close the software I need to disconnect my adaptater and relaunch the soft.
If anyone can solve this bug. Thanks in advance. :roll:
PS: Sorry for mistake I'm french
TurtleForGaming
Re: enttec open dmx Sowtware bug
UP !!
TurtleForGaming
So, after a lot of testing I think I found a solution. Seem freestyler doesn't like chinese ftdi boards. I just change the controler enttec open dmx by the EUROLITE USB-DMX512-Interface/Update-Adapter. The settings are the same.
Return to “DMX Interfaces”
