KEDSUM® USB to DMX Interface Converter Adapter
ServerCOMMAND
FreeStyler Version: 3.5.7
Post by ServerCOMMAND »
Hey listen I have the KEDSUM® USB to DMX Interface Converter Adapter Computer Controller LED DMX512 Console and I can't figure out how to connect it to freestyler. Anyone tell me how I can do this?
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Re: KEDSUM® USB to DMX Interface Converter Adapter
Post by buttza »
Are you trying to connect a controller to freestylerDMX or are you trying to connect a USB to DMX interface to freestyler?
Sounds like you are trying to connect 2 devices. :)
tdsii
Post by tdsii »
to use this with Freestyler, install the drivers on the disc, and in freestyler, choose "Eurolite usb dmx512pro" as the device and click advanced to select the correct com port.
MusicSync
FreeStyler Version: 3.6.3
Post by MusicSync »
I recommend below ArtNet to DMX interface and give up the uDMX.
http://hz.aliexpress.com/store/product/ ... 20451.html
Return to “DMX Interfaces”
