SunTriX and LedTriX are both matrix plug-ins for Freestyler.
These plug-ins allow you to create nice and attractive effects with a large number of fixtures (dimmer channels for SunTriX and RGB fixtures for LedTriX)
Before you can start using Suntrix and Ledtrix you must configure the addressing of the channels.
Once the addresses are set you can start using SunTrix and LedTrix.
Spacing : Used to spread the fixtures over the animation
Offset : move matrix start position (top, left by default)
Suntrix and Ledtrix have two layers: an animation layer and a text layer both with intensity and speed control and one master intensity control.
All settings can be saved under a macro button
- Animation: click an animation from the list, the animation starts to play
- Text: Input your text, color, font and click set.
- Set speed and intensity
- Press “Shift” key and press a macro button.
- Recall a macro with the F1…F12 keyboard shortcuts.
Animations are standard non-transparent gif animations.
Copy your .gif files in the animation directory (\Plugins\Animations and \Plugins\Ledanimations)
Suntrix automatically converts colored animations into grayscale.
