Feel free to enter text
Freestyler support One touchscreen to be controled with the Touchscreen Interface 1 or 2.
and Of course you can connect more touchscreens to a Pc.
Using Touch Screen Interface1
Using Touch Screen Interface2
You can use the keyboard to make Shortcut keys for triggering button on freestyler.
Keyboard shortcuts
The joystick control is enabled by checking “on” the checkbox.
When this is enabled all buttons on the joystick is active.
To control movement the external “Toggle pan/tilt” are be used.
See Joystick control
One Midi interface is available via a usb port.
If more midi interfaces are to be used then a patch program like Midi-ox and Midi yoke are to be used.
Midi-ox combines midi signal from more devices into one.
You can do alot more with midi ox and Midi yoke is a Virtual Midi cable, so you can connect the midi controler to Midi ox and from midi ox with a virtual Midi cable (Midi yoke) to freestyler
Using Midi Interface
Midi OX setup
Using BCF2000
Using 3x BCF2000 tutorial
