I hope you are well. I am really struggling to make my fixture work correctly .i have spent all morning but the head doesn’t do what it is supposed to . I am nearly there LOL.
I have attached my effort and any assistance would be greatly appreciated.
I copied the Rogue R2 that is on freestyler forum and then made changes accordingly.
http://www.chauvetlighting.com/chauvetr ... pot_UM.pdf
Kind Regards
Andy
www.discosuk.com
07584086369
RULES: Feature Request
- FreeStyler Version: DMX
- FreeStyler Version: Beta
Re: RULES: Feature Request
Hej Andy
You need to tell us where / what is failing for you.
One thing I can see is that the "Shutter ch." open is set to 12
In the data sheet is stated 4 to 7
And it is the same on the "Strobe ch.", you have low = 16 and high = 131
Should be low = 8, high = 76
There are more errors but I think you shall start with these then you have a not flashing light and you can work you way through the rest one by one.
