Help with Chauvet Intimidator 150 spot led [SOLVED]
Re: Help with Chauvet Intimidator 150 spot led
i just installed the chauvet derby x and it work as supposed too so i know my dongle is working.. i dont understand why i cant get the intimidator to work. im sure someone has used this light before on FS.
- FreeStyler Version: Beta
Hej again.
We have cleared that it is not the fixture file and that FS runs, as the output monitor shows which values that are send to the dmx dongle and they chances when you adjust the faders.
Somehow the enttec and intimidator don't like each other.
Here I am a bit lost but I think there are a update parameter which can be set.
I think it is under Interface setup -> Advanced.
I also think it will be a good idea to make a new post for help on the enttec dongle in the "FreeStyler Software" or "DMX interface" area.
There are many using the enttec dongle so it should be possible to get some help on this.
Just a silly question.
The fixture can in be set in different modes and if so, is it then set to the right mode.
Yay! i got it figured out. now i can move forward. What I did was discarded the profile i was working with and started from scratch one more time, after watching a video in a different language and not knowing what he was saying i just watched and picked up a couple of things i was doing wrong when creating the profile.. I'll complete the profile and up load it .. Thanks Jan for your support and help also
