I've tried literally everything to get the fixture to work with the given manual for dmx setup..Whatever i do when i try to change the color it does strobe and pulsing and everything it's not supposed to do, i think i'm making a mistake at "Function select 0-60",which frankly i don't understand what it means,could someone please help. If you can't try a shot at the profile,could you give me some tips as to what i,m doing wrong please. Below is the manual profile for dmx setup sheet...
DMX512 Channel
No. Function Details
Channel 1 Dimmer Dimmer for(R、G、B),Linear dimmer
,from dark to light
Channel 2 R dimmer Linear dimmer,from dark to light
Channel 3 G dimmer Linear dimmer,from dark to light
Channel 4 B dimmer Linear dimmer,from dark to light
Channel 5 Strobe R,G,B Strobe from slow to fast
Channel 6 Function select 0—60:DMX 7 channel control,
61-120: Jumping 121—180:fading;
181—240: pulsing; 241—255: sound activate
Channel 7 Function Speed from slow to fast
Fixture Setup Help!!
- FreeStyler Version: 3.5.7
Re: Fixture Setup Help!!
Is it the slimpar 56 you referred to in a different post? If it was there's a working one here viewtopic.php?f=62&t=3593
Otherwise it would probably help to list the make / model
No,this is another fixture
Can you upload what you have so far?
Or state the make & model? I have one similar and would adapt it for you if you can let us know what it is.
- FreeStyler Version: None
Could you try and upload manuals and the fixture like spud1511 said, so then we can see where you are at and help you. It just makes it easier than trying to read it from your post that's all.
