Hello everyone, just a short put the file changed, initially I worked the strobe, and the various effects of changing colors automatically, now everything seems to work! almost everything!
I have a problem, when I put the par together with scanners djsca250xt of stuff I can not get to play the scanners automatically, why?
Stairville Par Led 64 MK2 RGBW 10mm SI
- FreeStyler Version: 3.5.5
- I Use FreeStyler for: Film
- FreeStyler Version: Beta
Re: Stairville Par Led 64 MK2 RGBW 10mm SI
You don't need to pack it into "rar".
pff files can be uploaded direct. fxt can't
I put the following file almost complete, I placed the strobe was not working previously.
I can not get to make two independent programs with one scanner and one at the par why?
I am not sure what you mean by programming but I guess that you mean creating sequences and playing them back in a cue.
If so then here are an example from the wiki
http://www.freestylersupport.com/wiki/t ... playground
