Help Please - Showtec Phantom 50 Spot LED [SOLVED]
BillsGate
FreeStyler Version: 4.x
Re: Help Please - Showtec Phantom 50 Spot LED
Post by BillsGate »
It seems like you are using a 13ch fixture while the lamp is set to 8ch. I have set mine to 13ch mode
Uriahdemon
FreeStyler Version: 3.5.5
I Use FreeStyler for: Band
Post by Uriahdemon »
Hi Folks,
Does anyone have an Easy View 3D file for this fixture please. The built in one does not correspond with the FS fixture file due to the Pan and Tilt channels being built wrongly. The FS fixture file corresponds with the manual i.e. CH 1 - Pan, CH2 - Tilt, CH3 Pan 16 Bit, CH 4 16 Bit.
Unfortunately the Easy View 3D fixture file is set up for CH1 - Pan, CH2 - Pan 16Bit, CH3 - Tilt, CH3 - Tilt, CH4 - Tilt 16 Bit.
Any help greatly appreciated as I am not too good with EV3D fixture creating and need to get this sorted ASAP. I am working on it though and as soon as I have it sorted I will share with others.
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
Uriahdemon wrote:Hi Folks,
Hey, I've had a bit of experience with 3D files and creating them. If you wanna PM me the manual or post it here, then I'll see if I can create it for you like the FS one is setup :)
Uriahdemon
Hi Nathanars,
Just spent a little time sorting stuff out and it was the Easy View 3D fixture file that was wrong. So I have amended it and all good now. I am doing some experimenting before buying the moving heads I am thinking of. What was actually wrong was the Tilt and Pan 8/16 bit channels were the wrong way round.
I should really have spotted that sooner.
Thanks for the offer of help anyway. I am sure there will be another time pretty soon.
Rgds Mac
Nathanrs93
Glad you sorted it :)
