ADJ Comscan LED
- Just started using FS
- FreeStyler Version: 3.3.2
ADJ Comscan LED
Hello,
I have a pair of ADJ Comscan LED's. FS does not have a fixture profile for these and was wondering how I can get one. Can anyone help? I can try contacting ADJ to see if they have one I can download from their site.
Thanks,
Sergio
Thanks,
Sergio
- djSupport
Re: ADJ Comscan LED
Try to make yourself one its easy when you have the light there check out http://www.freestylersupport.com/wiki
Re: ADJ Comscan LED
Thank you, I will try that. I am so new at this that it's a bit overwhelming. I called ADJ this morning to no avail, they only create profiles for their dmx....too bad for me. It will be a great learning experience.
- LJ_krede.dk
- FreeStyler Version: 3.3.7
Re: ADJ Comscan LED
We encourage people to make their fixtures by them self, however that dosent mean we dont want to help... if you have (big or small) problems with the fixture creating, dont hesitate to ask for help, if you can upload the pff file and a manual for the fixture when you ask I guarantee you will get help asap.
/LJ_krede.dk
Aalborg, Denmark
Aalborg, Denmark
Re: ADJ Comscan LED
What is the pff file? I can upload the manual from adj, no problem. I am still working on creating the profile. The picture has been rough for me to get. It's a work in progress.
- remco_k
- FreeStyler Version: N/A
Re: ADJ Comscan LED
The *.pff file is the exported fixture profile. Contains everything needed. Including images.
You can export the profile from fixture creator using the export option.
Re: ADJ Comscan LED
I am waiting still for ADJ to give me the profiles so I can create something in FS, I hope soon cause I tried to create something without it and I was and am lost!!
Re: ADJ Comscan LED
I created a profile but am still not sure about channels 3 and 4, please see the files attached. It seems to me that channel 3 has 10 addresses and 4 has 18, but I only have 8 gobos. What do I do with channels 3 and 4?? I also used a generic adj picture instead of the comscan pic cause I couldn't get it to upload.
http://www.americandj.com/pdffiles/comscan_led.pdf
- LJ
- FreeStyler Version: 3.2.8
Re: ADJ Comscan LED
First of all you can bring the right picture in realy simple:
1.) Find the right picture (for example on the ADJ website or cut it out of the manual) and save it to your hard disc.
2.) Use a graphics tool to resize it (for example paint will do the job, or get an other free tool like IrfanView). About 70 times 70 pixel should work fine.
3.) Save the picture as a GIF file with transparent background (IrfanView can do so, do not know if paint can do) to the Fixtures folder inside the FreeStyler folder. (e.g.: C:\Program Files\FreeStyler\Fixtures)
4.) In FixtureCreator Click inside the "Fixt. Picture" field and select the file you just created. If you can not finde it in the list, try to hit "Imagelist -> Refresh" in the menu bar first.
Now to channel 3:
Your fixture seams to have different patterns for the strobing function: blackout and shutter open, "normal" strobing and two special strobing function with "slow open - fast close" and "fast oben - slow close". I do not exacly know what this means, but I think it means theat the shutter opens fast and closes slowly
Anyway: First fill in the fields for shutter closed = 0 (as you did) and open = 8. Then fill in some values for the strobing, low = 16, med = 58, high = 131. You may want to finde other values for low, med and high strobing by using the slider for the shutter channel in freestyler and watch what your fixture is doing. If so, feel free to adjust those values just like you want.
For the two special functions, you will have to crate macros. Try to finde out values you want to use for these patterns by using the sliders again. If you have one (ore more) values you would like to save in a macro just create the macros. Search this forum for detailed discriptions on how creating macros. I know there are some
Now to channel 4:
You are right in saying your fixture only has 8 gobos. But there is also an so called "open" gobo. In fact this is just a beam with no picture but will count it to the gobos as well So there are 9 gobos in the fixture. The fixture t also supports gobo shaking for each gobo. Gobo shaking means, that the gobo skakes a little and this will couse an effect as if its moves a little. You can compare this to a mirrow of a scanner wich is dooing a very little movment along the pan/tilt-axis. And that realy fast.
Your fixture has also a gobo wheel rotation, wich means that you can let the gobo wheel rotate through the gobos automaticly. You can adjust the speed of this. For this you should find out some values again you want to use. The lowest is 128, the highest 255. So med would be something about 192. I usualy take 5 values (super slow - slow - med - fast - super fast). You can adjust the values just like I told you with the strobe channel.
What you have to set up in fixture creator now is this:
You have 9 gobos, 9 gobo shakes and a number of gobo rotation speeds, lets say 5. So the number of gobos you enter at the Fixture config tab of FixtureCreator is 23 (=9+9+5)
Then you set up the 9 gobos as you did before but add the open gobo as well (DMX value 4 for example). Do the same with the gobo shakes again.
Then enter the values for gobo wheel rotation as well to the list. For example enter DMX value 128 as the super slow gobo wheel rotation.
Now you should finde suitable images for the gobos. Go trough the image list at the right side and finde them. If you can not finde the right ones to to create some on your own. You already got the manual on how creating the fixture picture. It is almost the same. Just use a 31 times 31 pixel image and save it in bmp (no transparent background) to the Gobos folder inside the FreeStyler folder (e.g.: C:\Program Files\FreeStyler\Gobos) If you have the right images for the gobos it will be much easier to hit the right gobo in everydays use.
Hop this helps with you problems. Do not forget to upload the ready fixture file to the user created fixture files section in this forum so that other can use it
PS: Mh... Just again I wrote such a long answere. And it is almost the same that I write. Perhaps I should sit down and prepare generic answere snippets wich I can use in the future. Or even better - I can write a detailed manual on how creating fixture files with all those points I always answer covered. But right now I do not have the time to do so - perhaps in the future
Now to channel 3:
Now to channel 4:
Re: ADJ Comscan LED
You are a lifesaver!!! I have most of it done and I am very happy. I have to still work a bit on the images on the right side or download some of my own. What does the transparent background do or not do? I uploaded the new fixture profile. It seems to work fine. Give me some feedback if you have any.
Thanks again for your help.
Last edited by sarellano on September 24th, 2010, 4:58 am, edited 1 time in total.
- LJ
Re: ADJ Comscan LED
the transparent background is good if someone has a background picture in FreeStyler for example showing his traverse. If you have no background picture the standard gray will shine trough the transparent sections of the image. If you have a white background in the fixture image you will see always this white square. Not realy likly
It is just for things look good and will not bring (or take) and functionality.
- Twitter: twitter.com/djxstatik
Re: ADJ Comscan LED
hello,
The profile works great in FS but i seem to have problems when trying to add this fixture to Magic 3D. the file is there but it doesnt let me add the fixture, I also tried to create it with scan Library but still no luck. is there a fixture file out there for Magic 3d. Thanks
Re: ADJ Comscan LED
Could anybody please post a pff file for the comscan, which is ready to use? I would love that!
Thanks in advance,
Best regards,
Arno D
Thanks in advance,
Best regards,
Arno D
Re: ADJ Comscan LED
I would love it, too. If anybody is out there who could post it would be much appreciated.
Cheerz and good light.
KS
KS
