HQ power Laser Topic is solved
Leon1404
HQ power Laser
Post by Leon1404 »
I have no idea how to make fixtures and have now for about 3 days looked in every fixture libary i could find.
BUT i cant find a fixture for my HQ Power laser : VDP1001RGYLD9
So plzz someone help me.
I dont now how to put pics in here but send me a mail then i email the protocol: Leo55@live.dk
Leon Christensen
Re: HQ power Laser
Post by Jan_K »
Hej Leon
It may be an idea to link to user manual so we have a chance to look at the fixture.
Leon1404
Re: HQ power Laser
Post by Leon1404 »
Sry. I didnt think i could find it online. This link may work:
http://www.hqpower.eu/downloads/4/vdp10 ... lfresd.pdf
Mvh. Leon Christensen
Re: HQ power Laser
Post by Jan_K »
Hej Leon
I have had a look in the manual and it is not that complicated but I think you are to make the fixture by your self as there are some thing where you need the fixture to try how it works.
As lasers don't fit into normal fixtures then you have to be a bit creative on placing the functionality.
There are a laser tutorial on the wiki which may help you.
http://www.freestylersupport.com/wiki/f ... ld_rs_200g
If you have any questions then ask and will try to support you.
Leon1404
Re: HQ power Laser
Post by Leon1404 »
Thank you for the tutorial, but i'm brand new in this freestyler thing so i simply dont understand the writing and sayings in the tutorial...
Leon Christensen
Re: HQ power Laser
Post by Jan_K »
Hej again
Here is a suggestion of how the channals can be placed.
What is missing is to set all the values for the patterns in the macro tab and the same with the color.
Every thin with a number icon you need to do something with.
But this should help you getting started.
Velleman_VDP1001RGYLD9_09ch.pff
Re: HQ power Laser
Post by Jan_K »
Well I can only say you have the fixture and you are the only one who can make it as it require the fixture to figure out the values for the patterns.
Leon1404
Re: HQ power Laser
Post by Leon1404 »
Thank you very much that was exactly was i've been looking for. I will try work on it now. Thank you again.
Leon Christensen
Re: HQ power Laser
Post by Jan_K »
There are still much work for you to do and when you start playing with it then you may figure out that it is not the optimal way to control the fixture.
When you have something you thing is okay then remember to upload it here again so you can help others.
