Showtec Bar 8 LED [SOLVED]
pitt76
FreeStyler Version: 3.5.5
Post by pitt76 »
does anyone have a fixture file for this LED Bar ?
thanks
Pitt
Nathanrs93
FreeStyler Version: None
Re: Showtec Bar 8 LED
Post by Nathanrs93 »
pitt76
Post by pitt76 »
Thanks but i want with 7 DMX channels (there are the differents programms in a channel, it's more simple )
pitt76
Post by pitt76 »
It's ok, i've created a fixature file
Re: Showtec Bar 8 LED [SOLVED]
Post by Jan_K »
Then Upload it :D
pitt76
Post by pitt76 »
yes, tomorrow
pitt76
Post by pitt76 »
How i import the file ?
Post by Jan_K »
You Export the fixture in Fixture creator. (pff file)
And upload it.
If you need to import a fixture then you double click on it or open Fixture creator and uses import.
pitt76
Post by pitt76 »
it's done
