Acme Cougar
apollodj
FreeStyler Version: 3.5.5
Acme Cougar
Post by apollodj »
Hi all,
New boy here, i've given it a go and tried to create a fixture for this light, it's only 4ch so should be easy right?
I even made my own gifs for the gobos for the unit, now my problem is it doesn't fire up in 3D mode, i havent got the usb-dmx yet so can't test direct but i've got a funny feeling i've missed something in the set up of the fixture.
Anywho, could someone take a look and give me some tips please, i've uploaded the manual as well, just in case.
Many thanks in advance
Dave
Re: Acme Cougar
Post by Jan_K »
Your fixture looks okay.
I moved the gobo images to a sub folder under Acme to avoid too many folders in the main path.
And I added some macros just for the fun of it.
ACME_LED_275D_Cougar_4ch.pff
"3D"
3D is a separate program and has nothing to do with FreeStyler.
You need to create a fixture in "Scanlibrary" which is the fixture editor for 3D.
( I have not checked if there is a Cougar fixture there)
apollodj
Re: Acme Cougar
Post by apollodj »
Thanks so much Jan, really appreciated, i'll go test now
:D
Nathanrs93
FreeStyler Version: None
Re: Acme Cougar
Post by Nathanrs93 »
Just like Jan_k said if you do need a fixture for 3D then you request some help here if you get stuck:
Click Here! :)
