New feature request: 'Loop all Sequences' option stored for each CUE
studijo
Post by studijo »
Hi Rapheal,
I use Freestyler often for wedding partys. Freestyler runs mostly all night in 'Automatic Pilot' let's say.
The only thing I do is select 3 predefined 'modes' (normal use, slow and fast).
To achieve this I made 3 CUE's with sequences:
The selection of the CUE which I want to use is made by the buttons on the right. VERY USEFUL !
As you know the CUE panel has the option to 'Loop all Sequences' (or not)
The actual limitation in FS is that this option is stored for the CUE panel in general.
Would it be possible, to store this option (loop all sequeces) in the CUE configuration file itself, so individually for each CUE file?
I mean, for example: when CUE A is loaded the 'Loop all Sequences' option is enabled because it's enabled for this CUE and when CUE B is loaded via the button panel on the right, the 'Loop all Sequences' option is disabled.
Hope some other FreeStyler users like also this functionality and it can be implemented easily.
Regards,
Johan
Freestyler 3.5.9 on Windows 8.1 with DMX4All USB interface.
BCF2000 with firmware 1.10
Fixture setup: 4 x PAR64 controlled by Dimmpack, 2 x Eurolite TSL-200 scanners, 1 x Ayra TDC-33, 1 x Geni FL-1800D strobo, 1 x Antari Z-1500 fog machine
studijo
Re: New feature request: 'Loop all Sequences' option stored for each CUE
Post by studijo »
Noone?
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
If you've not done already, it might be worth adding this as a request via bug tracker. Then Rapheal can think about considering if it's worth doing it or not :)
http://www.freestylersupport.com/bugs/main_page.php
Return to “Ideas and Remarks”
