First of all, thanks a lot for this great freeware. It makes it possible creating nice semi-professional setups for little money compared to professional solutions and also semi-professional software which are very expensive.
Really great is the midi implementation and i had a lot of suggestions in this case but i solved nearly everything with a midi translator.
But one of my biggest suggestions is, beeing able to save inverse pan/tilt individual for every fixture in the sequences. This would make it much more easy and would take less time creating better shows.
Freestyler is a great piece of software and is getting better and better. A big milestone was the 2nd Dmx universe and with some little improvements it's getting outstanding!
Big up to the programmer!
Matthias
beeing able to save inverted pan/tilt in sequences
- FreeStyler Version: 3.6
- FreeStyler Version: 4.01
Re: beeing able to save inverted pan/tilt in sequences
not sure if I understand your request but you can invert the p/t on any fixture by simply right clicking the icon on the freestyler desktop
Thanks for your reply. Yes i know that... But for better show performance it would be great beeing able to save this setting in the sequence. I'm controlling FS via an APC40 and fire the pre programmed scenes via launch buttons. So i have to remind which scene was programmed with normal pan/tilt and which scene was programmed with inverted pan/tilt... put my hand on the mouse and change the setting with the curser. That breaks the work/creativity flow. Now i'm trying to programm every scene with an inverted moving head (i have only 2)... but this i have set in the m-head software itself and if i want asymmetry in the moves its a lot of work and i have to be very precise because i have to program every step of every single m-head.
greets
greets
