hey there.
as of now, sequence play back midi mapping for reverse and random etc would be crucial.
the lastest version of 3.6.37 quicksave no longer works
i have been wondering if there is an ability to select certain submasters and then enact them all at the same time... including a fade time in that function would be crucial... example
i have 20 submasters.... 3, 5, 6, 7, 19 2o are running.... i know a change in a song is coming up so id like to be able to pre select a sequence in submasters 2, 3, 5, 6, 7, 14, 16, 17 and enable them all with one button. and if there was a function to fade from playing sequences to selected sequences, like that of the fade on and off command, that would make this software as good as any out there.
btw, i use this more that any other software... its almost the best one, be the club!!!
Give us some feed back [Split]
- FreeStyler Version: 3637
FreeStyler--Behringer BCF2000-Novation Launchpad-MUSTARDVISION MediaServer-HOG4PC-Ableton-Arkaos GrandVJ XT-ResolumeArena5-
Re: Give us some feed back
I know i can create a cue to involve these changes, but with limited cue availability, it makes on the fly cue building available and allows for extremely fast creations.
- FreeStyler Version: Beta
Hej Cralmu
Please report errors in the bug tracker.
And I think there is a feature request on the submaster functionality you want.
You can have a look and eventually comment on it to get focus on it.
http://www.freestylersupport.com/bugs/view.php?id=1233
