How to optimise shows for different size stages......???
- Uriahdemon
- FreeStyler Version: 3.5.5
- I Use FreeStyler for: Band
Hi, I have set up FS over the years to respond to certain moving head submaster cues regarding tilt/pan etc. What I have now regularly hit upon is the need to adjust the tilt/pan limits i.e. in a bigger venue needing to extend the values for greater coverage or in smaller venues reduce them.
Is there a simple way to do this please .....??
Mac
www.mclite.co.uk
www.mclite.co.uk
- FreeStyler Version: 3.637
Re: How to optimise shows for different size stages......???
Hello,
I have the same problem now. There is function in Setup menu http://www.freestylersupport.com/wiki/_ ... references which should control it, but it is not working for me
- Uriahdemon
Thanks Maros336. Are you using the submaster and/or cue buttons to control the lights.....?? It may have been obvious to you however it does mention that you have to control the fixtures using them for this to work
Mac
www.mclite.co.uk
www.mclite.co.uk
I am using submasters. Is that resize working for you?Uriahdemon wrote:Thanks Maros336. Are you using the submaster and/or cue buttons to control the lights.....?? It may have been obvious to you however it does mention that you have to control the fixtures using them for this to work
- Uriahdemon
I dont know as yet mate as I cant get my rig up for a few days. I will give it a try later using the visualiser and see if it makes a difference. I will update this thread as and when I do. Just wondering if anyone else reading this can provide any other tips....??
Mac
www.mclite.co.uk
www.mclite.co.uk
- Uriahdemon
Mac
www.mclite.co.uk
www.mclite.co.uk
Hello,Uriahdemon wrote:I dont know as yet mate as I cant get my rig up for a few days. I will give it a try later using the visualiser and see if it makes a difference. I will update this thread as and when I do. Just wondering if anyone else reading this can provide any other tips....??
do you have some new information? Have you already tested it?
- Uriahdemon
using visualiser seems to increase or reduce the movement of heads so pretty confident it may work on live rig. I will be using it from Nov 20th
Mac
www.mclite.co.uk
www.mclite.co.uk
- Uriahdemon
Mac
www.mclite.co.uk
www.mclite.co.uk
Did it working in reality?Uriahdemon wrote:using visualiser seems to increase or reduce the movement of heads so pretty confident it may work on live rig. I will be using it from Nov 20th
- Uriahdemon
just so happens I have my rig up this week so once I have got some time I will give it a try and let you know
Mac
www.mclite.co.uk
www.mclite.co.uk
- Uriahdemon
Mac
www.mclite.co.uk
www.mclite.co.uk
- Uriahdemon
Hi, I tried this last week and all worked fine as the guide suggests......??
Mac
www.mclite.co.uk
www.mclite.co.uk
What am I doing wrong?
