yes i also run version 2012.5.21.3054
and just like to add to it it's finaly a version that seems to work %^$#& great again.
allthough i did need to recreate my fixture's again, to let it work Perfect.
but i am realy happy with the lastest version.
Magic 3D Problem
- Spirit
- FreeStyler Version: 3.5.9
Re: Magic 3D Problem
- biggus
- Twitter: http://www.twitter.com/emrdisco
I'm glad your happy Spirit, wish mine would work. What version of windows do you run and what Das drivers are in your add remove programs?
- biggus
Ok a quick update, If I wipe my freestyler and magic 3D it works but I don't want to have to rebuild my stage from scratch neither I want to program all my routines up. Any ideas?
- FreeStyler Version: Beta
You can use the back-up function in freestyler and save the stage in 3D eventually also save the fixture from 3D in a backup folder.
It should then be possible do what ever you want with FreeStyler and 3D.
I have made a small stage tutorial on the "wiki" where the stage can be downloaded and used.
The FreeStyler is part in that tutorial is not saved with the backup function but all the single files alone.
You can have a look there and see how I have done it.
- biggus
I've managed to fix it
Not sure what went on but I did copy my stage from the old version of magic 3d and exported/imported my settings within freestyler in the past like I've always done and it worked OK.
To fix the 3D issue I had I went onto nicolaudie and downloaded the latest beta of 3d and installed it copied the EasyView.exe over to the freestyler installation folder and it worked.
- FreeStyler Version: 3.3.1
I had the same problem. No light beam from the fixtures. Just downloaded the latest beta of easy view and replaced the exe files. Vola! Did´nt need to do anything else. Thanks!
