3D easy View won't load Topic is solved
- FreeStyler Version: 3.5.9
- FreeStyler Version: None
- FreeStyler Version: 3.6.49
Re: 3D easy View won't load
Good morning everyone.. Same problem...
Solved:
1' Install Freestyler
2' Download Magic 3D view
3' Install Magic to the FreeStyler Folder (C:Freestyler)
4' Unzip MEVP.Zip and copy the files (not the folder) in c:\freestyler..
Enjoy...
Solved:
Enjoy...
- I Use FreeStyler for: Band
Thanks dodopas. Was tearing my hair out (what's left of it!) until I came across the golden nugget in your instructions... both Freestyler and Magic 3D Easy View must be installed into the same folder! No need to unzip MEVP.zip - it just worked straightaway. By default M3DEV was installing into it's own folder.
Oh, and don't forget to select the virtual interface as the interface in Freestyler setup.
