I would like to join the (beta)testing/dev of FS
martie
LJ
FreeStyler Version: 3.5
Twitter: none
Post by martie »
Dear Freestyler,
As I'm using Freestyler almost every week in our student union I would like to join the testing/development of Freestyler. Also I would like to contribute to new/better features and improve user experience. My current setup is a notebook with W7, Entec Pro and BCF2000. My lightning setup contains: 20 LED pars (4ch), 6 scanners, 2 Acrobats, a switchpack, some dimmers and a smoke machine.
Martie.
Nathanrs93
FreeStyler Version: None
Re: I would like to join the (beta)testing/dev of FS
Post by Nathanrs93 »
Have you applied in the group itself? If you do that and wait reply from the group leader, you might be able to join
martie
LJ
Twitter: none
Post by martie »
Where can I do that?
Nathanrs93
If you look at the top of the forum, go into user control panel, then usergroups and then you should be able to apply from there.
everyone is a member of the dev/beta team..
on the top of this page you can find the link "submit a bug report"
here you can add the issue/bug you find on FS and if you find imported bugs the devolper will send you a beta test version..
and if you keep doing this you will be added to the team and the devolper will send you without asking the new beta's.
